Home > Technical > fbh
rrsfreak
Belgium 2005 Range Rover Sport TDV6 HSE Bonatti Grey
fbh
hi all,
i know there are many post of this, but i have to ask,
my engine is changed, broken camshaft,
since then my fbh doesn't work normaly
sometimes it starts and sometimes not,
when i start the car you hear i'm go on and smel it and then shuts down
and sometimes it works normal,
what can be the problem
sorry for the english
Post #405904 Thu Dec 12 2013 4:45pm
Paddi
The FBH will not start if the vehicle fuel tank is low (below 1/4).
The FBH will not start if the temperature is above 4 degrees C (no snowflake symbol no FBH start)
The FBH stops if the ambient air temperature reaches 9 degrees C
In normal operation the FBH switches from full load combustion to part load combustion or to idle depending on the engine coolant temperature.
If none of the above explains the behaviour of your FBH then there may be a fault so you should connect a fault code reader.
Hope this helps Thumbs Up 2008 MY Java Black TDV8 HSE
Post #405906 Thu Dec 12 2013 5:18pm
rrsfreak
yes, i know these things,
it has no fault code's,
went to dealer and they put computer on it no faults and the system starts
few days later it don't work
went to a webasto dealer, they put the pc on it no fault , and run the complete cycle
now here in belgium it's on this moment 3 degrees and it won't start, you hear it go on and smel it but not working
Post #405908 Thu Dec 12 2013 5:26pm
Paddi
Is your battery in good condition?:
FBH - Battery Voltage Limits: 10.25 - 15.5 volts. 2008 MY Java Black TDV8 HSE
Post #405915 Thu Dec 12 2013 5:50pm
rrsfreak
yes is oke 12,5 v in the morning
Post #405916 Thu Dec 12 2013 5:55pm
http://www.rrsport.co.uk/gallery/albums/us...en-WEB.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #405957 Thu Dec 12 2013 10:51pm
