Home > General (L494) > New RRS - Humming noise when cruising over 50mph |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
4000 miles in my dynamic running on 22s
Wed Jan 01 2014 10:52pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
A few years back I picked up a bog standard Audi 1.9tdi from Munich airport and drove to Nuremburg , 100 miles in exactly I hour, torrential rain, and was still being overtaken by Audi A6s, Mercs etc doing vast speeds. |
Wed Jan 01 2014 10:53pm |
Plus with a half full tank, there's noticeable fuel sloshing noises from the tank on braking. |
Wed Jan 01 2014 10:57pm |
Just travelled 40 miles on the motorway, with the radio off and driving a set speeds of 50, 60, 70, 80 + mph. No hum/drone at any of the speeds and no change in the noise level, at any of these speeds.
Thu Jan 02 2014 1:31pm |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 |
So that is a draw then.
Thu Jan 02 2014 1:59pm |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
Fuel tank sloshing , i am told there will be a fix for that ! 2014 5.0SC AB
Thu Jan 02 2014 5:18pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
I asked the dealer from where I've ordered my car and they have had no customers complaining of wheel noise on 22" wheels. |
Tue Jan 07 2014 7:55pm |
dastardly Member Since: 15 May 2008 Location: here Posts: 2 |
Wheel alignment. Wishbone suspension alignments should be checked. |
Wed Jan 22 2014 11:24pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
Wonder what the fix will be, normally baffles inside the fuel tank which is often a difficult item to get at/replace. Makes you wonder how the car made it into production without that being noticed. Mark SVR in Estoril Blue |
Fri Jan 24 2014 7:00am |
qzaitz Member Since: 28 Feb 2014 Location: BC Posts: 4 |
I have also been affected by the droning noise. Just like most, it happens at certain speeds and with 22" rims. It just started making the noise a few weeks ago. I'm thinking it's to do with the tire wear, but it really sounds like it's coming from the engine. |
Fri Feb 28 2014 9:57am |
AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96 |
I have a similar problem, but noise at lower speeds, 30-40mph. I recently had my RRS service by dealer and they say it is tyre noise, which probably coincideswith me having two new General Grabber tyres on the front. Still annoying though as i keep thinking it is mechanical.
Fri Feb 28 2014 12:46pm |
doldy Member Since: 10 Dec 2013 Location: Norwich Posts: 23 |
Just an update here, still doing it, although you do of get used to it. But shouldn't really have to in a high end car such as these!
Mon Mar 17 2014 10:38pm |
Gal Dove Member Since: 14 Aug 2012 Location: A bus stop under The Westway. Posts: 61 |
Got an RRS HSE with 22's on order. This sounds a bit worrying........but not entirely consistent...?
Tue Mar 18 2014 1:21am |
hornbaek Member Since: 11 Dec 2013 Location: Richmond Posts: 39 |
I have done 7000 miles in my RRS SC with 22" wheels now (50% on M+S and 50% on winter tyres). The noise is still there on both sets of tyres. A bit less on the winter tyres as the general tyre noise suppresses the underlying humming.
Tue Mar 18 2014 7:28am |
