Home > In Car Electronics > Dead Touch Screen
drdelrrs
Dead Touch Screen
On my 2013 MY the Touch screen screen went 'black' but radio etc still worked.
As we know usually switching off leaving the car to go into 'sleep' mode will clear most of these glitches as LR's system is actually quite robust and its rare for the screen to be blacked out its more normal for it to freeze and all functions to be lost.
It can appear that there is a blown fuse.
However we tracked this down to indigestion with the USB storage device that had iTunes music file installed. Apparently if a USB has any system type files (often hidden) it can cause the system to go into shut down. Removed the USB dongle and everything is back as normal.
Lesson is be careful to clean format the USB device so the music files are the only files on the drive. Thumbs Up
Post #405132 Fri Dec 06 2013 6:55pm
Andypar
2012 Range Rover Sport SDV6 HSE Lux Fuji White
my screen also does this and i did not have any USB installed. There is alledgedly a software update for this fault but after having tried this, the dealer is now fitting a new unit but they are on a 3 week back order. Really useful that!
Post #408297 Mon Jan 06 2014 9:47am
carmadscott
sounds like new unit Neutral
Post #408438 Mon Jan 06 2014 10:58pm
