Home > In Car Electronics > Where is the Bluetooth module located please ???????
highfellzippy
HELLO ANYONE KNOW WHERE IT IS
I THOUGHT IT WAS ON THE RIGHT HANS SIDE IN THE BOOT BUT CAN'T FIND IT ?????????
Has it moved 2005 tdv6 ???
Post #404414 Sun Dec 01 2013 12:33pm
skilachi
Go to the this link and select your car.
http://www.bluetoothexchange.co.uk/
On the RRS 2005, its on the right hand side but you will need to open the black side panel in order to get proper access to it.
Post #404417 Sun Dec 01 2013 1:04pm
highfellzippy
It's not there only a tc module ???
Post #404418 Sun Dec 01 2013 1:14pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Are you sure you've got one? Does it work?
Post #404438 Sun Dec 01 2013 3:52pm
Bodsy
Site Sponsor
You've probably got the dealer fit BT modules which is at the front centre console, one module on each side. I suspect that you used 0000 to connect to the BT.
Factory fit (or retro factory fit) is 2121 Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #404453 Sun Dec 01 2013 5:46pm
