Home > Maintenance & Modifications > Hid Xenon bulbs
GibRRS
Gibraltar 2007 Range Rover Sport TDV6 SE Stornoway Grey
Hid Xenon bulbs
Hi all, quick question. I've heard that HID headlamp bulbs last a lot longer than a normal halogen bulb. Do you carry spare HID D2S bulbs? If so could you pass on the k rating, ( for a 2008 MY ). I have seen that there seems to be different types, will fitting higher k rated bulbs damage the headlamp lens?
Many thanks
GibRRS
Post #403103 Thu Nov 21 2013 9:05pm
largestorage
England 2006 Range Rover Sport TDV6 SE Java Black
As I understand it the k is the colour, 4300 would be a crisp white light with a hint of yellow upto 1200k which would be really blue. We sell hundreds at work and 6000k outsells all the rest put together
Post #403184 Fri Nov 22 2013 10:08am
GibRRS
Thanks for the info Largestorage.
regards
GibGSA
Post #403221 Fri Nov 22 2013 2:00pm
The K is the colour temperature. It stands for Kelvin, hence the capital k. As Kelvin is the absolute temperature scale (it starts at absolute zero, i.e. 0K) it doesn't have "degrees" in front of it Thumbs Up
Colour temperature is the hypothetical colour that would be produced by an ideal black body at that temperature, it's not the temperature of the bulb in your unit. The colour you see is caused by the chemicals used in the unit rather than the actual temperature of the bulb, if that makes sense. 2012 SDV6 - it's missing a couple of cylinders
Post #403286 Fri Nov 22 2013 9:44pm
GibRRS
Thanks RRSTDV8, I was a bit worried that if I picked a higher number it would be more powerful and hotter and end up deforming or marking the plastic headlamp.
BTW what number do you think would be more or less the same as stock versions?
Many thanks
Regards
GibRRS
Post #403295 Fri Nov 22 2013 10:23pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Need new D2S bulbs for my 2006 Sport. Anyone got a link to some superwhite/bluish bulbs? RRS 2006 2.7 HSE
Post #403411 Sun Nov 24 2013 12:04am
Advanced Factors
Site Sponsor
http://www.advancedfactors.co.uk/66240xnb-...3821-p.asp Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #403456 Sun Nov 24 2013 6:22pm
Marsie
Just noticed mine when i pulled up to my garage door tonite. The o/s headlight is bright white and the n/s one has gone pink Rolling Eyes . Time to buy a pair of new ones me thinks Big Cry . Sods law that most of the places round here that do them are shut till after christmas
Paul Current fleet
2011 Discovery 3.0 sdv6 XS
2008 Range rover sport HST tdv8*gone*
2000 Porsche 911 Carrera 2 convertible
1996 TVR Chimaera*gone*
2004 Vauxhall combo van*dead* Sad
2003 ford ranger double cab
Post #406827 Fri Dec 20 2013 6:19pm
