Home > General > Windscreen wipers |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
If the vehicle started ok then it's not likely to the battery. Most likely is that the motor's fried and/or something has seized in the mechanism that links the motor to the wiper arms. Check the relevant fuse to see if its blown. 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 13 2013 1:59pm |
Anders-01 Member Since: 25 Jul 2012 Location: London Posts: 13 |
Hi , thanks for reply , have checked all fuses etc . Just seems a bit strange that the last time I used car they were fine . The wipers do start to move but stop after about 3 inches have assisted them across the screen and back to there resting place . ( on a wet screen of course ). I said I wouldnt buy another one ! |
Wed Nov 13 2013 4:08pm |
No ones messed with the bolts that connect them have they?
Wed Nov 13 2013 4:22pm |
Well as the temperature outside was below zero in the London area last night could it be that the wiper blades were frozen to the screen?
Wed Nov 13 2013 4:49pm |
Thanks guys for replays , it was cold but didn't go out to car until the sun was up so not frozen to screen . Will take wiper arms off in the morning and see if the splines are moving freely ( good idea ) hope fully I will just need wiper arms and not a new motor , have any of you guys change a motor before ? Looks a pig to get to . Anyway will update tomorrow . Have a good evening . I said I wouldnt buy another one ! |
Wed Nov 13 2013 5:00pm |
Anders,
Wed Nov 13 2013 5:05pm |
Have just found another post marked wipers gone mad , that was about the securing nut on wiper arms loose so hopefully you are right and my nuts are loose ( excuse the pun) will check in morning , fingers crossed ... Thanks again I said I wouldnt buy another one ! |
Wed Nov 13 2013 5:22pm |
Surely it would be unusual for both wiper arms to become loose on their spindles at the same time and to the same extent ?
Wed Nov 13 2013 5:28pm |
Anyone no how the plastic cover comes off across the bottom of windscreen to reveal the motor and rods ? I said I wouldnt buy another one ! |
Wed Nov 13 2013 5:42pm |
Funnily enough just looked this up as I'm changing my faded warped one as soon as the new one turns up
Wed Nov 13 2013 6:23pm |
Cheers Paddi , will be ripping that off tomorrow to see what I can see I said I wouldnt buy another one ! |
Wed Nov 13 2013 6:55pm |
Back again , plastic cover at bottom of windscreen came off easily to reveal wiper motor and rods , removed wiper mechanism and took motor off the rods , motor works ok . On further inspection of the mechanism ( not motor ) the near side had completely seized . Because I had not used car for a few weeks even then maybe no need to use wipers it looks like rain water runs down n/s wiper shaft and on to the mechanism below causing the shaft to rust . So if like Paddy you remove the plastic cover to renew it make sure you grease any moving parts on the wiper mechanism while cover is off . Have orderd complete wiper assembly including motor ( could not find mechanism on its own ) used part sourced on ebay will be here tomorrow .
Thu Nov 14 2013 5:21pm |
Thanks Anders; that was a top tip
Wed Nov 20 2013 2:38pm |
