Home > Maintenance & Modifications > Remapping somerset/dorset area
Adsgrey
Can anyone recommend anywhere that can do the following
DPF removal
EGR removal/blanking
ECU remap
The above is for a RR sport tdv8 on a 57 plate, ideally would like to find somewhere in the Somerset/Dorset area , but will travel if really needed.
cheers
Ads
Post #401159 Tue Nov 05 2013 2:40pm
I'm not sure your vehicle has a DPF fitted.
Post #401160 Tue Nov 05 2013 3:04pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Yours won't have a DPF and the EGRs can't be removed on RRS 07> onwards. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #401171 Tue Nov 05 2013 4:53pm
Adsgrey
Ok, that saves time and money then , cheers.
Any recommendations on a good place for the remap alone in the Somerset/Dorset area?
Post #401173 Tue Nov 05 2013 5:08pm
Advanced Factors
Site Sponsor
I would recommend Bell Auto Services in York, yes I know York is the other end of the world from you but you will get a first class job, not a 10 minute fiddle with a lap top.
Pete Bell is also working on a hardware (not software) solution to removing later EGR valves but don't bug him with it, it is work in progress and he will post up when it is available (lots of threads on the D3 forum)
Book it in and spend a day shopping in York, great place anyway even if a bit far. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #401174 Tue Nov 05 2013 5:51pm
If you're just going to get a remap done (the EGRs can't be blanked and you don't have DPF) then just buy a BAS remap unit. The new map is sent by email and the whole process is fairly straight forward. 2012 SDV6 - it's missing a couple of cylinders
Post #401175 Tue Nov 05 2013 6:07pm
Adsgrey
Cheers for the info I will look into it.
Post #401177 Tue Nov 05 2013 6:21pm
Rossc77
2006 Range Rover Sport TDV6 HSE Java Black
Where' abouts are you matey Rudkins near Crewkerne in somerset can offer remaps
Post #401183 Tue Nov 05 2013 7:34pm
Adsgrey
I'm about 20 mins from there ill have a look, cheers.
Post #401186 Tue Nov 05 2013 7:45pm
tonytiger
England 2010 Range Rover Sport TDV8 HSE Bali Blue
Hi I can't recommend Alive Tuning highly enough, I believe he now has somewhere in reading that will it his recaps, a little trek I know but tbh you need one based on recommendations Thumbs Up
Have a look and listen to his tdv8 on his web page www.alivetuning.com
Post #401208 Wed Nov 06 2013 7:37am
The 90 on 20inch RRS wheels looks terrible. Just horribly wrong.
Where is the TDV8 you refer to? 2012 SDV6 - it's missing a couple of cylinders
Post #401232 Wed Nov 06 2013 10:39am
tonytiger
Hi in YouTube search "alive tdv8" it's the first one at the top
Sounds sweet Thumbs Up
Post #401236 Wed Nov 06 2013 11:15am
