![]() | Home > Advanced Factors > Osram replacement front FOG Lamps with DRL kit |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
It may be they will fit straight into later models, not got one to look at |
Knowing your luck Muddy, you will fuse all your electrics and blow both headlight bulbs. |
Yes, I have been looking at the bumpers & lights, early Sport is the same as my Disco, later bumper style has the same light bracket arrangement as the Osrams so I am pretty confident they are a like for like fit. Paul Redding
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Sounds like a good idea and I was interested up until the point when it turned out they didn't fit without modification.
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 ![]() ![]() ![]() |
I don"t understand why the light opposite the indicator goes out....normally the indicator side dims and the opposite side stays as it is..so a bit lost...otherwise still interested as I have MY 13 so hopefully will just fit on |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
its the cornering assit, loads of new cars do it, but the fog comes on with the indicator whats on |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 178 ![]() ![]() ![]() |
anyone fitted them to a range rover sport 2005 |
Maci, speak to Disco_Mikey he's in your neck of the woods. |
ok thanks |
can anyone tell me what are negative spacers if you use this then there is no trimming of fog light bezels needed |
