Home > Faults & Fixes > diesel tank
deputydog
2006 Range Rover Sport TDV6 HSE Java Black
diesel tank
any of you guys know if theres a drain plug for the diesel tank I presume its got loads of crap in it as after a few hours driving engine system fault keeps coming on then it wont start and not getting any diesel but if I stick the airline on pipe and blow it back to tank once I reconnect diesel pipe fires straight up replaces the diesel filter a couple of weeks ago and it was great for a week then its back again
Post #398946 Fri Oct 18 2013 6:33pm
Disco_Mikey
No there isn't. What your problem is likely to be is the pick up filter on the bottom of the pump. The bio-growth in the tank gets sucked into the filter, blocking it. No other option but to drop the tank and lift the pump out
Post #398950 Fri Oct 18 2013 6:55pm
deputydog
is it a easy job before I start I have the use of a 4 post ramp
Post #398951 Fri Oct 18 2013 6:58pm
