Home > Faults & Fixes > Window one shot...
tonytiger
England 2010 Range Rover Sport TDV8 HSE Bali Blue
Window one shot...
Hi all, my windows all round do one shot lowering but NW don't do one shot up?? Had to disconnect battery for remap.... Is ths the reason why?? Can it be turned back on??
Thx tt
Post #398085 Fri Oct 11 2013 8:45pm
TT yes you'll need to reprogram them Thumbs Up
Quote:
WINDOW RESET
The windows will need to be reset if the battery
is disconnected, becomes discharged or power
supply is interrupted.
Reset as follows:
1. Close the window fully.
2. Release the switch, then lift it to the close
position and hold for 1 second.
3. Repeat the procedure on each window.
 ON THE WAY: BMW F21 M140i
Post #398086 Fri Oct 11 2013 8:48pm
tonytiger
Top job that man...... Just been out and sorted them
Thank you very much Thumbs Up Thumbs Up
Post #398087 Fri Oct 11 2013 9:22pm
