![]() | Home > Faults & Fixes > Catalytic convertor replacement on RRS SC |
Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35 ![]() ![]() ![]() |
Also guys mabye I should say also about a slight roughness engine idle. It's only slight between 250-500 rpm approx 4-5 times when u apply light pressure to accelerator when stopped and again when u come to a junction for example and stop before pulling out
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
At the risk of stating the obvious, the Catalytic Convertors are missing on both banks, so the lambda sensors will not be reading correctly. You need to rectify this, before looking any further into the issue |
Yes mate but the Lambda spacers are meant 2 sort that aspect of it out. Ie they trick the computer into thinking readings are ok and in theory the EML never comes back on
You answered your own question. In theory...
Fink ya might be right
