Home > Technical > Turbo blown
engine-kid
United Kingdom 2007 Range Rover Sport TDV8 HST Chawton White
Turbo blown
Hi all my 2007 hse 3.6v8 has blown turbo and won't start any ideas what else is wrong
Post #396154 Wed Sep 25 2013 3:33pm
haven't you just bought this?
Isn't the garage sorting it on warranty Shocked
Post #396157 Wed Sep 25 2013 3:43pm
muddywheels
Milk Float Man
Bad news - Simple1 is sadly the expert on these Sad
http://www.rrsport.co.uk/forum/topic29765.html Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #396158 Wed Sep 25 2013 3:51pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
An all too common problem with the TDV8, a friend of mine had both Turbos go on his recently and it cost him £5.5K to get it fixed by a Landrover dealer... Shocked Shocked Shocked
Post #396163 Wed Sep 25 2013 4:42pm
muddywheels
Milk Float Man
We heard you the first time Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #396167 Wed Sep 25 2013 4:45pm
Laughing Whistle
Post #396175 Wed Sep 25 2013 5:58pm
Paddi
Re: Turbo blown
Sorry to hear about your problem.
If the engine turns over you may be able to save it. If it won't turn over the cylinder(s) may be full of oil and the engine is probably toast.
Assuming engine is otherwise OK you will quickly find that fixing it is a major job and very expensive. The turbo is about a thousand pounds and replacement is a body off procedure about 7 hours labour in itself. It is essential to find and rectify the cause of the failure or the new turbo will go the same way. This can include replacing oil feed pipes and the intercooler. It would be false economy not to replace both turbos whilst the body is off. Unless all this work is done perfectly the problem will soon recur.
Think your best option is return to seller for a full refund and second best is fix under warranty and then get rid. 2008 MY Java Black TDV8 HSE
Post #396313 Fri Sep 27 2013 8:51am
