![]() | Home > In Car Electronics > Retro fitting TV in 2006 RRS SC |
Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42 ![]() ![]() ![]() |
There are retrofit options, I know NavTV has been mentioned on here a few times. A search should bring up some reviews that could be helpful.
Double Post |
BWGRRS Member Since: 18 Jun 2012 Location: barrow-in-furness Posts: 70 ![]() ![]() ![]() |
I definately would not consider, sticking a ugly, unsightly arial, on the car.
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
I am no expert, but I imagine that there must be an internal aerial solution, but maybe the signal would be an issue! MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
You have the GVIF unit so use one of the other av inputs and just select that input with the toggle button to view TV on your touch screen, there are some good internal powered aerials in some of the dearer TV kits.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
flack - is there any you would recommend ? |
I have fitted some kits for customers with these aerials and they said it was good reception, the aerials where mounted in the rear quarter light windows away from any airbags.
Sorry flack - is there any ' TV tuners ' you would recommend - I have the GVIF unit fitted. Just lookin to add to it. |
PEACHY
Flack - Do you offer the supply, and fitting of the TV option. |
