Home > Faults & Fixes > Brake pads changed but warning light still on
Whizzee111s
England 2010 Range Rover Sport Supercharged Santorini Black
I've just had the front pads and sensor changed but the warning light is on,amber, and the LCD screen still shows the info warning check brake pads. Also had the back ones checked but not changed.
This was done at Kwik fit who have said that if it doesn't go out after a few miles of driving then to take it back, should the warnings not clear themselves or does it need to be cleared via a computer? Freelander SE - Gone
S1 Elise - weekender
Rrsport S/C Autobiography 10 plate -well and truely here, but now stolen
Post #395010 Sat Sep 14 2013 4:24pm
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
I am unable to give advice, but I would be interested in finding out what needs to be done to clear the warning.
Post #395012 Sat Sep 14 2013 4:41pm
flack
Are you sure they changed the front sensor and checked the rear one, if they have replaced the front and the rear was ok then it should have gone out as soon as you turned the ignition on, there is still a fault on the system.
Have they fitted the correct sensor the ones fitted to these are not like the normal sport ones..
The rear one is faulty.
As for the it going off after mileage what a load of crap.. but you did use quick fit. Shocked
Flack Thumbs Up
Post #395014 Sat Sep 14 2013 4:50pm
Whizzee111s
They told us they did as we had to wait for it to turn up from the suppliers, not supplied with the pads money grabbing ......, we are taking it back tomorrow. He showed us the pad with the sensor fitted and the lead was like two feet long.
They did check the rears but had 50% left Freelander SE - Gone
Post #395018 Sat Sep 14 2013 5:42pm
MXSRR
Flack Thumbs Up
Whistle
Post #395023 Sat Sep 14 2013 6:42pm
Whizzee111s
Only for the life time guarantee lol Freelander SE - Gone
Post #395042 Sat Sep 14 2013 10:18pm
Whizzee111s
All sorted the new sensor was realigned and now the fault has gone Freelander SE - Gone
Post #395060 Sun Sep 15 2013 12:35pm
