![]() | Home > General > Fuel tank sensor fault |
largestorage Member Since: 28 May 2013 Location: mirfield Posts: 30 ![]() ![]() ![]() |
Friendsa got a 2010 rrs and fuel sensor is intermittently failing, reporting the tanks empty when it's not, anyone had this before? Is it a simple fix? Likely to get anything from range rover as its out of warranty |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Wiring issue in the O/S/F wheelarch, or faulty sender unit. One can be replaced, the other can't, and needs a new tank.
One sounds costly and the other doesn't, he's on his 2nd landrover (I bought his old one) but he didn't buy this one from a main dealer as he was so unimpressed with our local dealer first time round! Worth a try though and thanks for advice |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Be very careful with this. I had a faulty sender an the car seemed ok for a few days, just meant I had to be sure I kept it topped up as the gauge read empty. BUT, a few days later the car kept shutting off the engine... Very scary at 60 mph going round a bend |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
^^ safety feature !!! Sounds more dangerous than been safe. |
^^ too right, my steering went like concrete mid corner. It took all my strength to keep the car from crossing onto the other side of the road |
