Home > General > My first RRS purchase. |
Rangestar Member Since: 05 Sep 2013 Location: Northampton Posts: 8 |
I forgot to say it is a TDV6 2.7. Nit sure if i should consider a TDV8???? |
Fri Sep 06 2013 11:13pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Sorry, but to be brutally honest, if you are on a short budget then the RRS is not for you. If you buy a Sport then you need to be able to chuck serious cash at it at short notice. Why? Because it's a complicated design built by low skilled half wits in Brum.
Fri Sep 06 2013 11:18pm |
Thanks for that, but i am used to things going wrong as my jaguar xj has started doing that too. Jus thought i wold try and get a heads up before i purchase a lemon of a vehicle. |
Fri Sep 06 2013 11:24pm |
Soooo do you have any useful tips for my first purchase then???? |
Fri Sep 06 2013 11:25pm |
The 2.7 requires a belt change at 105k miles or 7 years (whichever is sooner).
Fri Sep 06 2013 11:59pm |
Hi RRSTSV8
Sat Sep 07 2013 12:31am |
sellick Member Since: 26 Jul 2013 Location: Bath Posts: 47 |
Check that the air suspension functions correctly as that can be a common fault and costly to identify/fix. EGR valves are also an issue, but if you are looking at 2005/6 models they are very easy and cheap to blank. Might be worth asking if the seller minds having a diagnostic check done just to confirm there are no underlying issues before you purchase it. The spare wheels also often get stolen so worth checking that! Other than that, good luck, you will love it! Unfortunately mine will be up for sale shortly |
Sat Sep 07 2013 1:27pm |
Also, worth holding out for one with decent service history, and ideally receipts for bushes being changed. In my opinion, high mileage isn't so much of an issue as long as it's been properly maintained and looked after. |
Sat Sep 07 2013 1:29pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
He's not exaggerating either.... we're talking parting of the sea stuff Main points to look out for. Symptom: Sluggishness of the mark... coupled with black soot Possible Causes (cheapest to most expensive): a: Split intercooler hose (£60 b: EGR failure (£500 to replace (each, there are 2) or block off (pre 2007 cars only) £15 kit and your own labour c: Turbo blown ££££ Symptom: HTC error on dash a: blown brake bulb £0.60p b: Tracking out (causes same error) £190 at dealer... £60 independent c: suspension leak £labour to find the leak d: Compressor duff (£700 RRS gone Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Sat Sep 07 2013 1:45pm |
A full service history is essential in my opinion. Any gaps in the history and one should walk away. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Sep 07 2013 3:05pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
What a ! the list off problems & failures are mostly components not because some half wits have fitted them incorrectly. Yours truly - Dummy Brummie 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
Sat Sep 07 2013 3:23pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
If you read all the story's on here I doubt you will buy one.
Sat Sep 07 2013 4:04pm |
BrianCarlin Member Since: 02 Sep 2013 Location: Lanarkshire Posts: 19 |
How can you blame the guys that build them
Sat Sep 07 2013 4:50pm |
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 |
Yes it's not the guys that build them, it's just a very expensive, complex machine to run. I spent £1k+/yr just in servicing mine when my local indie looked after it.
Sat Sep 07 2013 8:39pm |
