Home > General > Looking at buying a 2009 RRS
RRS2013
Hi everyone,
I been reading this forum for a week or so now and whilst the info and support are fantastic I'm becoming increasingly worried about the front suspension knocking and potential other costly problems.
Is there an idiots guide on here that tells the would be buyer what to look out for. I suspose the usual full LR service issue is crucial but what else should I be looking for and which diesel engine should I go for.
Which is the best engine TDV6 or TDV8. I'm considering nothing earlier than 2008 but again what about high mileage? Is that a major problem. And gear box etc.
Thank you for any replies as never bought a LR never mind a prestige car.
It sounds as though the purchase of a 12 month warranty is crucial. Have most people on here bought off main dealers or are independent garages a good source. I'm in Lancashire.
thanks again .
Very Happy
Post #393606 Mon Sep 02 2013 8:43pm
PEACHY
Welcome to the site Thumbs Up if you use the search function on the top menu bar this will help with your queries there is too much to list & many opinions on this subject.
Good luck - welcome to the madhouse Very Happy 16MY Estoril Blue SVR.............
Post #393624 Tue Sep 03 2013 6:33am
The basics are:
Buy the best one you can afford. Full service history is a must but could include work from a decent independent LR specialist. The TDV6 requires the belts to be changed at 105k / 7 years. Note that all services are time or distance so the vehicle should have a service entry every 12 months as a minimum. Any missing services, walk away - there are plenty of RRS out there.
A warranty really is essential.
The TDV6/TDV8 question is unanswerable I'm afraid. Some prefer one to the other and you need to drive both and consider the fuel usage of both. The 3.0TDV6 is a lot better than the older 2.7 (and probably on a par with the TDV8) if your budget stretches to it.
If you want a modded one, be very careful - better to buy a standard one and mod it yourself. Then you know what has been done and what parts were used. Good modded RRS come up occasionally in the For Sale section of this site so might be worth a look there if that is your thing. At least that way you can see what has been done because they will probably have a thread somewhere about the work they've done.
Watch out for vehicles fitted with 22inch wheels. There are a number of cheap copies of well known wheels out there. Check the load rating of the wheel and whether it is genuine e.g. Overfinch. Be aware that the RRS was never designed to run 22inch wheels and fitting them may lead to earlier replacement of suspension bushes. Try one with 19in, 20in and 22in wheels if you can and see how the ride is affected and whether that is an issue for you.
All RRS need bushes doing at some point. The anti roll bar bushes seem to be considered consumable items by LR. Wishbone bushes wear too. A knock through the suspension when dropping a wheel in to a pothole probably indicates ARB bushes needs to be replaced. Not expensive and has been done DIY by some hereabouts. Wishbone bushes are less commonly required but cost more as the old ones need to be gas torched off the vehicle. New wishbones are then fitted. A bit more expensive than ARB bushes.
Other than that, the usual rules apply - make sure everything works. The RRS's electrical system is a bit of a diva and likes to throw the toys out when seemingly little things go wrong. A blown brake light bulb can cover the dashboard in error messages. Yes, really. Also check the air suspension. It should raise quite quickly. The rear goes up slightly before the front. If it's very slow to raise that would suggest a weak compressor that might need replacing. 2012 SDV6 - it's missing a couple of cylinders
Post #393631 Tue Sep 03 2013 7:08am
PEACHY
SPOT ON Bow down Bow down 16MY Estoril Blue SVR.............
Post #393632 Tue Sep 03 2013 7:11am
RRS Daz
Really good post that rrstdv8 Thumbs Up
Post #393724 Tue Sep 03 2013 7:30pm
BKHK
The 09s are good. Last before the MY 10 facelift. Can be spotted by the factory body colour boot strip. Mine was fantastic, never gave a hint of trouble. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #393751 Wed Sep 04 2013 11:37am
RRSLover
Welcome onboard and if anything you are in the right place if thinking of buying a RRS.
I'd suggest not to rush out and by the 1st car you see, spend time trawling through the posts and you will no doubt learn alot.
Then compile a list of must-haves and watch-out for and go test drive both TDV6 & TDV8.
Only then will you know what to go for..Goodluck and happy hunting.
Post #393764 Wed Sep 04 2013 1:35pm
H16UUP
United Kingdom 2006 Range Rover Sport TDV6 SE Zermatt Silver
I'd agree with above comments. You might want to check out this link as well. TDV6 2.7 in Discovery 3 is same as that fitted to RRS.
http://www.disco3.co.uk/forum/topic97369.html
Go for FSH only. I'd go for one from an independent LR specialist if there's a good one near you. 2006 TDV6 SE, Zermatt Silver
Post #394257 Sat Sep 07 2013 8:48pm
roscopcoltrane
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Agree with the above, number 1, test drive, only then will you know if an RRS is for you, trust me you will know instantly, then ignore (to an extent) all doom mongering (is that a word), they are fantastic cars if you look after them. I have been through all the usual suspects but still jump into the RRS for a smile !!
Post #394264 Sat Sep 07 2013 9:48pm
roscopcoltrane
Post #394265 Sat Sep 07 2013 9:48pm
