![]() | Home > Maintenance & Modifications > Mudflap fitting - improvement |
Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42 ![]() ![]() ![]() |
Nice work, I hate those sprung clips. |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
it's a Maclaren Merc SL !!! |
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 ![]() ![]() ![]() |
Nice one, wish I had put them in instead of those spring clips, stupid idea. I fitted the OEM mudflaps last month, took me ages getting the screws in as it kept pushing the clips apart grrrr |
Red71 Member Since: 13 Jun 2013 Location: Perth Posts: 13 ![]() ![]() |
"BTW in theory you can fit the mudflaps without removing the wheels but access is very limited so if you have the equipment - remove the front wheels. As for the rears - I found it is necessary to jack up the rear to gain access to the screws but not necessary to remove the wheel."
Not surprised. The screws supplied with the kit appear to be too big for the spring clips. The guy in my bolt factors said they are 'self threading screws' not self tappers (or paint clearers). 2008 MY Java Black TDV8 HSE ![]() |
Corroded screws is probably more of a problem for us in the UK with salted roads so I Like to take no risks and use a lot of pressure with a Pozidrive. Didn't think of using a pozidrive bit in a socket though ![]() ![]() ![]() |
