You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > General > Things to look out for on a RRS at 50k
sammyclinigan
What kind of things should I be looking for on a RRS that is just under 50k or has completed 50k? Are there certain replacements that should have happened?
If an RRS is over 60k miles should I expect any changes to be made.
Looking at 08-10 models as a range.
Sat Aug 24 2013 1:52pm
SCdavies
I brought mine at 52k with nothing replaced.60k I had to change the compressor. Otherwise all has been well. So I think you ll be alright at 50k.
Sat Aug 24 2013 7:34pm
sammyclinigan
How much did it cost to replace the compressor?
When are the big services needed on the RRS? Is it at 60-70k range?
Sun Aug 25 2013 2:36pm
SCdavies
drive in and out replacement £500 from an Indy garage. As to servicing depends on model. I believe on this forum there is a service chart. Try the search section. Cheers
