Home > Maintenance & Modifications > Reversing Camera
Page 1 of 3 123>
Reversing Camera
For you guys who don't have one but would like one, this looks a decent bit of kit. Even suitable for you caravanners. Thumbs Up
http://www.hids4u.co.uk/reversing-camera-f...der-2.html
Post #392296 Tue Aug 20 2013 8:57am
Big Dave
I agree, the ccd cameras do give a good quality image. Not sure I'd part with £89 for one though, I paid under £20 for mine. 2011 Evoque Si4 Dynamic plus lux
2007 Audi TT 3.2 V6
2005 Sport Sc
Post #392298 Tue Aug 20 2013 9:33am
MisterAdam
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Am I right in assuming it's not as simple as buying the camera and plugging it in?
What else is required to have the camera work with the standard screen? Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Previous: Mercedes CLS, BMW 330cd M sport, Nissan 200sx, Impreza STi, EP3 Civic Type R
Post #392302 Tue Aug 20 2013 10:22am
Doesn't Bodsy fit rear view camera's for a reasonable price Question Might be worth a pm, unless he picks up on this thread and posts his comments. Thumbs Up
Post #392304 Tue Aug 20 2013 10:27am
flack
On the RRS it should work ok once enabled in the CCF its the D3 that needs the Gvif unit to make the camera work in reverse.
Flack Thumbs Up
Post #392317 Tue Aug 20 2013 1:15pm
Flack, would that camera work as plug and play (with CCF updated) on a 2008 RRS? Presumably one needs to run a cable from the boot to the back of the dash? How easy is the CCF update? 2012 SDV6 - it's missing a couple of cylinders
Post #392323 Tue Aug 20 2013 2:21pm
flack
Yes just run the video feed to the front and the rest can be wired from the rear passenger side of the boot, the CCF edit is nothing much for this, its just a section like below image
Flack Thumbs Up
Post #392333 Tue Aug 20 2013 5:19pm
daveyc
United Kingdom 2006 Range Rover Sport Supercharged Siberian Silver
Did you change the ccf if so where was the connector Question for the camera input located and what type was it thx Dave 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
2007 2.7 v6 Chrysler Sebring convert sport
2006 SRT8 6.1 ltr petrol 300 Chrysler gone
2005 X5 3.0d sport gone
2001 BMW 330 ci ltd edition mtec gone
Post #424277 Wed May 14 2014 3:36pm
daveyc
Post #424278 Wed May 14 2014 3:37pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I really miss my camera from the last car. I've the TV unit is it simple to buy a camera and plug and play?
Post #424335 Thu May 15 2014 12:35am
TMUNRO87
Hey guys so ive installed the gvif unit (piggy backs the sat nav dvd player) and a TV tuner, ive done a description of my install and will post photos on the thread later. It was quite easy to do, now I have the reverse camera left to place, need to work out how to tackle the boot though
Post #424359 Thu May 15 2014 9:10am
daveyc
I want to change the ccf config so it runs automatically through the denso screen without have to have it switched to sat nav, just need to know where it plugs in location and type of connection for the camera 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Post #424365 Thu May 15 2014 9:19am
daveyc
Got my IID Tool change the ccf file for the rear camera to on but when I select reverse no change on the denso screen , anybody done this ( not using a gvif) 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Post #426446 Fri Jun 06 2014 4:38pm
daveyc
Touch screen mod
Okay so just changing the CCF does not enable the reversing camera , so after a little help off the disco forum there is a simple mod (1 wire cut) that enables the reversing camera also the venture cam to be used , the reversing camera is automatic when selecting reverse NO MATTER what screen you are in , i did not want to add a gvif as you have to be in sat nav also £ 250 ish for what its only a switching unit and i have spare av's so wasn't prepared to spend to get extras anyway doing the mod to the denso screen now gets my cd player , Bluetooth phone and few more extras on the touch screen far better than the original setup on the little radio display .....
http://disco3.co.uk/forum/topic74474.html?highlight=brightness
All credits to the respective people who come up with this Bow down
Thumbs Up 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG £0.60 per ltr)
Post #428281 Wed Jun 25 2014 7:33am
tanloverluke
daveyc, are you telling me that the hids4u reversing camera will work on the rrs (i have the 07 hse) WITHOUT the gvif unit, with the added benefit that the reverse screen comes on regardless of what screen you're initially in?
I just have to ask to clarify, because it seems too good to be true...a upgrade for £50 that I thought cost £300+
cheers! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #428329 Wed Jun 25 2014 1:43pm
Page 1 of 3 123>
