![]() | Home > Technical > Turbo |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The actuators can seize. It's a known fault I believe. The solution appears to be to free the actuator and apply a lubricant. Should be covered by warranty if you're covered by LR's warranty. 2012 SDV6 - it's missing a couple of cylinders
