Home > Maintenance & Modifications > Groaning sound from front suspension????
BRY460
Hi,First post so be kind to me. Very Happy
2005 HSE 2.7 V6 when going round right hand bends a groaning sound from what I was told was the front bearing hub(near side).This has now been changed and the noise is still there.Note it does not make the noise on left turns.The noise can now also be heard in a straight line and is getting worse Any ideas ??? The two front lower arms have also been replaced along with the discs and pads.
Does the car have to go back to Land Rover as the arms have been done, and the stearing wheel is no longer central. Thanks in advance Brian J.
Post #390285 Sun Jul 28 2013 7:34pm
Bradders
Sounds like ARB bushes to me. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #390286 Sun Jul 28 2013 7:50pm
BRY460
Hi thanks for the quick reply but what are the ARB bushes (sorry for my ignorance)and bad spelling Embarassed
Post #390287 Sun Jul 28 2013 7:53pm
BRY460
AntiRollBar bushes....ARB Cool
Post #390289 Sun Jul 28 2013 8:13pm
ShooterNeil
Have you not had the tracking done they set the stearing wheel first
Have a look at the stone Guard around the back of the discs see if its been knocked
Post #390290 Sun Jul 28 2013 9:01pm
BRY460
Hi, can the tracking be done at any tyre place or is it Land Rover only,does the wheel alignment have to be done when the lower arms have been replaced also Land Rover or anywhere ? Thankyou for your input.
Post #390293 Sun Jul 28 2013 9:06pm
ShooterNeil
yes your wheels will be all over the shop who changed the arms did they not do it
You don't need to go to land rover ever if you find the right place
Post #390297 Sun Jul 28 2013 9:11pm
BRY460
The guy that did the work,works for the car dealer that I bought it from,dont know if he did the tracking after or not I will phone tomorrow to find out.As for the wheel alighnment do you mean a 4 wheel alighnment or a garage that knows what they are doing.
Post #390298 Sun Jul 28 2013 9:15pm
Where ever you go to get the wheel alignment done, make sure they can put the vehicle's suspension in tight tolerance mode while they do the work. 2012 SDV6 - it's missing a couple of cylinders
Post #390299 Sun Jul 28 2013 9:17pm
ShooterNeil
Best to get the full alignment done camber toe tracking x4
On a hunter system it's fully computerised
Kiwk fit can do it if they have the new hunter kit fitted
Post #390301 Sun Jul 28 2013 9:20pm
ShooterNeil
What difference dose that make
My car was just left running as they did it
Post #390303 Sun Jul 28 2013 9:22pm
BRY460
Thanks to you all for your replies,I will endevour to get it sorted and I will come back to you with the outcome..
Post #390304 Sun Jul 28 2013 9:22pm
The suspension system has two sets of tolerances. In normal mode, the system will ignore a wheel that is up to 15mm (I think) high or low. This means that any two wheels could be "out" by 30mm relative to each other. As suspension moves the camber changes (the wheelbase changes too between rides heights too by the way). Tight tolerance mode has a tolerance of +/- 5mm (I think).
If the vehicle were to be set up with the maximum normal tolerance, it could be a long way out when driven on the road.
Any tyre place should have the necessary means to activate tight tolerance mode. If not, you have to ask why not. My local place recently bought a 4 wheel alignment rig. When I asked for a price he said he couldn't do it yet because he couldn't yet access tight tolerance mode on LR products. This is the sign of a good company and the reason I've been using them for years. As I have the IIDTool I could set it to TTM myself and they did the work. 2012 SDV6 - it's missing a couple of cylinders
Post #390334 Mon Jul 29 2013 12:04pm
michealewk
I think mine are gone too how do i know if mine has ACE or not
Post #390341 Mon Jul 29 2013 1:50pm
BRY460
Took it to Kwikfit this morning,,they just did it in normal mode using the Hunter system they did not ask about tight tollerance mode!They did say though that because I had just had the lower arms done that the bushes may settle a little so take it back in a couple of weeks for a re-check and adjust free of charge.Tghe camber,toe and tracking was a mile out with one reading not even on the chart.Still got a small groaning noise on right hand bends but I think it is coming from the offside bearing now,may swop it for the one that I had replaced as I suspect that that one may be OK.cant do any harm as its not a massive job to do.The cost from Kwikfit....£64.90 for the front and rear alignment,the back was also out but not by much.....
Post #390345 Mon Jul 29 2013 3:49pm
