![]() | Home > General > Brembo brakes |
Don't mess about get genuine or you will have more problems than enough. The pads are 150 and discs @ 100. I'm sure you will get some discount from site sponsors. If you fit copy parts you will end up with warped discs and pads that break up as your trying to stop 2.7 tonnes. You can get away with copy pads and discs on rear though |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4440 ![]() ![]() ![]() |
Have fitted many aftermarket Brembo discs and pads. Never had an issue. Steer clear of Britpart discs though...
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 ![]() ![]() ![]() |
Cheers guys, I do want genuine brembo parts though |
I need front and rear pads and front discs and maybe rear discs aswell if not too expensive, may aswell do the lot!!!! Hopefully a partner company of this site will give me a nice price please!!!! |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
Hi
^^^ bargain |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
Green stuff pads with drilled and grooved discs on the front of mine £150 for the full kit, never had a problem and they look and work better than the solid brembo discs, u don't have to have Brembo pads or discs. Java black 2006 |
largestorage Member Since: 28 May 2013 Location: mirfield Posts: 30 ![]() ![]() ![]() |
I have two brembo front discs part number 09.8877.30 and pads P44018 which i can do for £145 delivered if you are interested |
