Home > General > Range rover sport lowrering links help?
f1_1rfn
Hi im going to be lowering my sport with the links to get a better stance Smile.. Guy fitting it has said il loose access mode which is fine.. My question is can i put the suspension back up and drive at normal height for log journeys? The guy fitting them said he thinks theres a speed limit of around 70 and the car will lower itself? Anyone with links on their sports can shed any light will be greatly appreciated Smile
Post #389044 Tue Jul 16 2013 9:47pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
hi mate i have lowering links on mine and if i put it in access mode it lifts straight back up again but drive normal when up, i do get a suspension warnig light on now and again tho , links take about 30 minutes to change
Post #389047 Tue Jul 16 2013 10:07pm
f1_1rfn
Thanks for reply.. So when your in normal driving mode your car sits low? And when you choose access mode it raises to normal drive height and stays there no matter which speed? Where did you get yours fitted?
Thanks
Post #389052 Tue Jul 16 2013 10:27pm
If you fit lowering links then the height the links give is the new "normal" height. If you choose "access" then it will bottom out and return to the new "normal" height i.e. the height set by the links. If you choose "off road" then you'll get a 50mm increase in height but it will return to "normal" at approx. 30-35mph.
If you want it to run at the correct height for longer runs then you would need to replace the lowering links with ones of standard length.
The alternative is to buy an EAS Tool or IID Tool which allows you to electronically set the ride height. This would allow you to return to standard "normal" mode ride heights as required.
The penalty for wanting gangsta-chav low ride most of the time is that you end up either putting up with it all the time or spending a couple of hundred quid to have the option of proper ride.
I might add that if the chap doing the alterations for you doesn't understand the system then he's probably not the chap to be using... 2012 SDV6 - it's missing a couple of cylinders
Post #389054 Tue Jul 16 2013 10:40pm
f1_1rfn
Thanks for reply is this what i need?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=190687032386
Post #389055 Tue Jul 16 2013 10:57pm
That will allow changes to be made to ride height. Use it carefully, however, as the Sport is quite sensitive to suspension set up and if done incorrectly then you can eat through tyres. 2012 SDV6 - it's missing a couple of cylinders
Post #389059 Wed Jul 17 2013 6:51am
f1_1rfn
thanks i ordered the EAS unit glad i posted a thread here otherwise would of bought the lowering links Big Cry
Post #389365 Fri Jul 19 2013 7:27pm
cossiedave
THATS A LOT BETTER SET UP THAN THE LINKS
Post #389374 Fri Jul 19 2013 9:23pm
PEACHY
I have the EAS unit it does 'what it says on the tin' cracking piece of kit but be aware as previously mentioned even the IID tool can cause tyre problems & It does make a difference to the ' ride ' a lot more sensitive - especially speed humps & potholes Evil or Very Mad
If you set it too low & try to use access mode it bottoms out & goes into extended height mode. I use it every now & then Whistle weddings & prom nights Rolling with laughter Rolling with laughter apart from that the novelty soon faded.
If you haven't ordered 1 yet a place in Kent does them at a reasonable price ( cheapest I've seen ) .
Thumbs Up Thumbs Up 16MY Estoril Blue SVR.............
Post #389376 Fri Jul 19 2013 9:31pm
f1_1rfn
Thumbs Up Thumbs Up
I have had previous cars with rock solid coilovers nearly touching the ground lol so ride dosnt bother me Smile
I paid £225 delivered which was exactly what the links guy was charging supply and fit.. Cant wait to get my car back from paint so i can lower it and post some pics up Smile
Post #389378 Fri Jul 19 2013 9:50pm
PEACHY
What are you driving ? - only your profile isn't showing your RRS Sad
Post #389380 Fri Jul 19 2013 9:57pm
f1_1rfn
I got a 2.7 tdv6 bought it totally standard in silver so gathered all the parts to transform it Smile it went into paint last week didnt want to go down the wrapping root .. Having it done in pearl white really itching to get it back! But on the other hand im driving my r8 weekend car more Smile il post pics of both soon as i get the range back Thumbs Up
Post #389382 Fri Jul 19 2013 10:01pm
PEACHY
I would only consider 1 other colour RRS Whistle - white Bow down 16MY Estoril Blue SVR.............
Post #389383 Fri Jul 19 2013 10:05pm
f1_1rfn
Was thinking of doing something diffrent like matt grey or a bright colour but i dont think it would look that good so chose a real nice creamy pearl hopefully should look good !
Post #389384 Fri Jul 19 2013 10:14pm
PEACHY
I work at Jaguar - the new F Type in red is something special - If I won big money I'd order a new RRS in the same colour & a helicopter Laughing & a yacht Laughing 16MY Estoril Blue SVR.............
Post #389385 Fri Jul 19 2013 10:19pm
