Home > General > Tasmod's sill problem
Page 3 of 3 <123
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Use silicone sealant to stick them down. I use this to stick all sorts of things down. It takes a while to cure (all night), but works a treat. Becuase it is very flexible, things don't come loose with vibration, heat etc and it resists water and weather. If you need to remove the item, the silicone sealant can be 'peeled' off okay too.
On my VW van, I had chrome handle covers and chrome mirror caps. Both had the same sticky tape as Tasmod's sill covers. They all eventually failed, so I restuck them with clear silicone sealant (bathroom sealant) and it worked well. Using sealant is ideal for sticking things down on uneven surfaces too. I've just stuck a GPS magnetic base down on the dash of my Disco3 with it too. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #46853 Thu Jul 27 2006 8:55am
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
I don't know what you guys are doing in your D3's, but my Range Rover Sport certianly isn't a bathroom. Evil or Very Mad Evil or Very Mad Evil or Very Mad Very Happy Very Happy Just yanking you chain
Post #46947 Thu Jul 27 2006 4:06pm
tony wright
United Kingdom 2006 Range Rover Sport SDV6 HSE Zambezi Silver
Mine has been confirmed Nov build with delivery Dec. They swapped the £500 deposit I had on the V6 to the V8 without any problems.
Post #46951 Thu Jul 27 2006 6:55pm
Bobby
And how did 'Tasmod's sill problem' play a part in this? Confused Confused
Wink Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #46959 Thu Jul 27 2006 11:14pm
Richchad
Well Tasmod kindly sent me some more double sided tape to restick my sill plates Smile
Have kept the two existing strips of tape on plates as they still seemed quite sticky and added two more strips in between the existing ones, so a total of four strips of double sided tape now.. Surprised
However just checked it again today and both the front ones appear to have come loose in the centre nearest to the inside of the car, so if you touch them, they sort of rattle.. Sad
I guess I will have to try the silicone sealent suggested by d3matt next.
Shame really especially as Tasmod went to all the trouble and expense of sending me more tape. Arrived - RRSport 2016 HSE SDV6 HSE
Loire Blue/Ivory leather Privacy Glass
Gone - RRSPORT 2010 TDV6 HSE
Stornaway/Ebony Premium leather with Lunar stitching, Heated Steering Wheel and Privacy Glass.
Gone - RRSPORT TDV6 HSE
Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course.
Post #47185 Sun Jul 30 2006 5:37pm
Richchad
Well Tasmod has kindly replaced all my sills as it seemed my original ones were very slightly oversize, causing them to ride up the inner bodywork sill curve. Sad
Fitted the new ones, all seem to remain stuck so far. Smile
Many thanks and well done Tasmod Thumbs Up Arrived - RRSport 2016 HSE SDV6 HSE
Post #48615 Fri Aug 11 2006 10:51am
This is the same problem I have! I will try the silicone trick. 2005 Zambezi TDV6 - Gone but not forgotten
Post #48617 Fri Aug 11 2006 11:22am
Bobs_buggy
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
I had the same problem. Tasmod made me another set that were 3mm narrower, and they fit fine now.
Bob. RRS 4.2 S/C. Zermatt. Tints. Stormers. 150+ paint defects, wonkey bonnet, scratches, detached doorseal. suspension faults. To sum it up, a �60k pile of cr4p!
Post #48635 Fri Aug 11 2006 4:07pm
Page 3 of 3 <123
