Home > Faults & Fixes > Engine system fault
Higgy456
Engine system fault
My rrs 06 tdv6 has just stopped completely on me , still got power and turns over but refuses to start , had aa out and looked at it and it never showed any more info on his diagnostic machine other than a engine system fault , he says its a fuel issue , he also sprayed quick start down the breather and it fired up for a sec hence he says its a fuel issue , pump pressure was only 1.4 say it shout be 4000 or something . Anyone had this problem before.
Post #388691 Sat Jul 13 2013 12:23am
Bodsy
Site Sponsor
Do a search for hpfp and lpfp
One is in the fuel tank and the other at the back of the engine Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #388709 Sat Jul 13 2013 10:03am
Higgy456
Thanks for the reply , I can hear the low pressure pump working away when I turn the ignition on , the aa guy thought it could b the hpfp to , this could get expensive Sad Big Cry
Post #388710 Sat Jul 13 2013 10:14am
deputydog
2006 Range Rover Sport TDV6 HSE Java Black
ive just had this problem changed diesel filter and now all is spot on
Post #398287 Mon Oct 14 2013 9:49am
Higgy456
Thank for the response , turned out to b the diesel pump belt had came off . All better now .
Post #398311 Mon Oct 14 2013 2:09pm
