Home > In Car Electronics > swapping stereos |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Just fitted a Kenwood touch screen unit to a Disco3. But required completely rewiring the system and excluding standard amp and functions. £18 interface makes steering wheel buttons work but you loose interface with dash. You will also need to replace standard speakers as they run on 2ohm and no retro amp can support it. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jul 04 2013 8:49am |
Well I never knew that! Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Thu Jul 04 2013 9:01am |
I didn't either until the standard speakers prematurely desolved 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jul 04 2013 9:05am |
