Home > Technical > plooms of white smoke after 2h idle |
That's what happens when you idle these for a long time. No idea why, but probably just that the engine isn't hot enough to burn off whatever it is that causes it. But its normal and shops be fine for your trip unless you're getting some fluid loss somewhere else? Bodsys Brake Bible
Wed Jun 26 2013 12:35am |
Leemot Member Since: 26 Sep 2012 Location: Manchester Posts: 5 |
thanks for your reply there is no fluid loss anywhere feel a bit better now cheers |
Wed Jun 26 2013 7:17am |
Firstly - tick over wont really put much charge through anything...it will charge a little, but i wouldnt run the car to try and charge the battery etc.
Wed Jun 26 2013 9:11am |
