Home > Technical > Special systems off and no power 2.7 tdv6
chuckmiester
2006 Range Rover Sport TDV6 HSE Java Black
I was towing a caravan at weekend up a steep incline on m1 when the message special systems off appeared on dash and car whent into limp mode. I turned car off and back on again and all was fine until the return journey home where it did same thing again. Is this a common fault or just maybe an electrical gremlin. Apologies for my original post as it was in the wrong area of the forum.
Post #384175 Tue May 28 2013 3:29pm
Saeedasghar
Mine did this and turned out to be a sticky egr valve. Best to get it on the old diagnostic machine tell you straight away if it is the egr.
Post #384177 Tue May 28 2013 4:06pm
chuckmiester
Egr valves are blanked of. Big Cry Big Cry Big Cry
Post #384178 Tue May 28 2013 4:08pm
Mine's currenlty doing the same.
Jury's still out on if it's a sticky egr or sticky turbo actuator rod
Have you a fault reader? RRS gone
Post #384179 Tue May 28 2013 4:09pm
Saeedasghar
Could be a pipe round the turbo with a slight split. As from what you described happens when the engine is under heavy demand. Need fault codee ideally to point you in the right area
Post #384182 Tue May 28 2013 4:19pm
chuckmiester
car going to Doug Dransfield indie today to have codes read. Hope I can get it sorted, taking caravan to silverstone to British gp at end of June.
Post #384233 Wed May 29 2013 5:37am
chuckmiester
Got car back from Doug Dransfield and the fault was "turbo over boost". They said because the car has never towed before the variable vain turbo might not be fully working because of a carbon build up. The car is running fine with no caravan on the back and as the caravan is only borrowed I think I'll let the problem develop.
Post #384274 Wed May 29 2013 4:55pm
I'm thinking the same.
You might find it's actually a sticking actuator rod at maximum boost, causing this sudden overboost.
Mine's running a modified map, so I'm going to remove the map prior to the next caravan outing and see if I get the same fault. RRS gone
Post #384310 Thu May 30 2013 8:12am
Paddi
What we need is for someone brave to try this turbo cleaner on their V8: http://innotecturboclean.co.uk/
There is a pretty genuine video of a guy not connected with the manufacturer's using it here:
So who is going to volunteer? Smile 2008 MY Java Black TDV8 HSE
Post #384353 Thu May 30 2013 3:03pm
