Home > Faults & Fixes > Suspension test fail:rear axle imbalance 60% |
Doesn't 60% imbalance usually refer to braking efficiency? One side at the rear is braking 60% less than the other. 2008 MY Java Black TDV8 HSE
Sun May 26 2013 10:22pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
In this case it is suspension response.
Sun May 26 2013 11:20pm |
Exactly how is that 60% figure derived? Was it with engine running and suspension at normal height? Don't have any other ideas but am sure someone with more knowledge will be along soon 2008 MY Java Black TDV8 HSE
Mon May 27 2013 8:58am |
it is basically the suspension response at each corner to a excitation input from a test pad under the wheel.
Mon May 27 2013 6:44pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
No, UK MOT doesn't test suspension like that. Like this site? Buy some RRSPORT goodies to show your support! |
Tue May 28 2013 10:58am |
its probably the response rate of the Shock absorber itself.
Tue May 28 2013 11:30am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
What does the car sit like is it level measure from the centre of the wheel hubs to the top of the wheel arch on each corner and post your results.
Thu May 30 2013 12:38pm |
in the US at the moment but will measure when I get back.
Fri May 31 2013 3:20am |
Ben200 Member Since: 13 Jul 2013 Location: Manchester Posts: 3 |
Are sure it's not a 60% imbalance across the axel something like that I'm an mot tester and the brake test regulations in the uk anyway have recently changed could be due to your brakes on the back not pulling evenly as in one side may be getting a reading of say 500 and the other side reads 350 therefore would fail on an imbalance across an axel hopes this helps some. |
Sat Jul 13 2013 2:55pm |
left rear airbag replaced. retested... no imbalance.
Tue Aug 27 2013 8:44pm |
GRsport Member Since: 25 Aug 2013 Location: Dublin Posts: 3 |
I think I have the same fault with mine, how much did this repair set you back and was it a main dealer job ? |
Fri Dec 13 2013 11:21pm |
had to get done with main dealer as I was away and the wife wasn't going to do it! ha ha
Fri Dec 27 2013 1:27pm |
