Home > My Range Rover Sport > Off to pick up the new RRS |
Sounds like a faulty stick - try another Mike
Thu May 16 2013 5:07pm |
Warren G Member Since: 09 Mar 2010 Location: Herts Posts: 98 |
How weird. Popped out this morning and ignition on.....thought i'd hit the USB on the screen and me all my music appeared and played no problem. |
Fri May 17 2013 9:49am |
Tail End Charlie Member Since: 10 Aug 2011 Location: Bristol Posts: 14 |
Mine worked on and off for a while....I worked out after swapping them around that it doesn't work consistently well with USB's over 2gb in size. |
Fri May 17 2013 10:44am |
sounds alot like cheap memory sticks cause the problem Mike
Fri May 17 2013 2:32pm |
