Home > General > VERDICT OUT - considering legal position -
jack.bauer
Was back on the ramp today and this is the verdict
The knocking sound is the arm that has play. Reason it wasn't noticeable before is because the arc system wasn't operating hence the intermittent suspension warning light.
Now that has been fixed by replacing the shut off valve, the arc system is operating and exposing the issue with lower arm.
Sorry if that doesn't make sense, trying to relay the mechanic's answer 07 TDV8 + BAS map
Post #380639 Tue Apr 16 2013 11:05pm
simple1
That sounds plausible. So it sounds like the active system was disabled to disguise the fault, is that what they are saying? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #380640 Tue Apr 16 2013 11:11pm
jack.bauer
Yes.
THe hissing sound I mentioned is in in fact rust on the front discs and despite they not being end of life, they recommend replacing disc and pads replaced. Isn't that hammer to walnut approach? 07 TDV8 + BAS map
Post #380727 Wed Apr 17 2013 4:07pm
jack.bauer
Updated the original post with the outcome of this 07 TDV8 + BAS map
Post #438468 Fri Oct 03 2014 11:33pm
simple1
Result although you should not have had to resort to this. I hope the dealer gets a visit from Trading Standards too. Interesting to know who the warranty was with, a company or the seller? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #438475 Sat Oct 04 2014 6:44am
jack.bauer
A warranty 2000 jobby sold with the car.
I took out my own with warranty direct who have been good so far with works done at main dealer. 07 TDV8 + BAS map
Post #438486 Sat Oct 04 2014 11:16am
