Home > General > Car won't move! |
Tonyrec Member Since: 15 Mar 2009 Location: Cumbria Posts: 306 |
After 10 minutes of sitting still, pressed starter and its working as normal.
Fri Apr 05 2013 2:26pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
Think this happened to me. Car would not start as brake pedal could not be pushed. When i did force the brake pedal the car started and the pedal went back to normal, been ok ever since. SVR 2018 in Santorini Black. |
Fri Apr 05 2013 6:39pm |
All appears well again. This is the first 'problem' that we have had in nearly 2 years of ownership.
Fri Apr 05 2013 9:55pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
If its an early car, ore 2007 roughly, may be worth checking that it has had the vacuum recall done on it. The servo was loosing pressure which made the pedal go hard with engine off. My 2005 V6 did it on a regular basis and required all my 15 stone to press it far enough to start the car.
Fri Apr 05 2013 11:59pm |
Hiya, it's a July 2010 model but I will check it anyway, thanks for the suggestion. |
Sat Apr 06 2013 7:05am |
FF1078 Member Since: 25 May 2011 Location: East Yorkshire Posts: 69 |
My 2010 TDV8 did it after a few days of ownership, I did the embarrassing thing of get LR assist out to look at it and he checked battery etc. then asked me what I was doing to start it so I showed him and he said press the brake pedal a bit harder and "whoomph" it started. I think I have a habit of putting my foot on the brake when switching the car off like the starting procedure and this uses the vacuum from the servo so it's rock hard the next time you come to start it which means the pedal doesn't go down far enough with a light press like normal to actuate the switch to say your foot is on the brake. No big deal and now when it happens I just push brake harder.
Sat Apr 06 2013 8:06am |
Cheers Nick,
Sat Apr 06 2013 8:21am |
