Home > Technical > RR Sport 2010 TDV8 Engine Light and Restricted Performance
amirmughal
Kenya 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Need help ! Just picked up my newly imported 2010 TDV8. Upon first keyless starting, had a Restricted Perfromance on the dash and engine light ON. I relaized there was no diesel in the car, filled up, reset the car few times (switch On and OFF), still no change.
Next Hour, made it to a workshop with a Launch scanner - scanner read Turbo B booster performance error, cleared that, engine light went off but red triangular light stayed on. Drove for 10 mins, suddenly all hell broke lose and all my warnings came on, from 'Lean when cornering' to Transmission Fault' , 'Special programs Off' 'Forward Alert' and 'Park Brake Failure'...I am terrified on the first day of getting this ...
Someone please help and advise. Whats happened here to a fairly new low mileage car from a reputed dealer in UK ... Amir Mughal
RRS 2006, Zambezi Silver, HSE, FACE LIFT 2012
Post #379601 Thu Apr 04 2013 7:35pm
Java SC
2005 Range Rover Sport Supercharged Java Black
You do need to scan the error codes so somebody can help you, also get the battery voltage checked and recharged if required, lot's of weird gremlins can be caused by low battery output.... Thumbs Up Java RRS Supercharged + Jaguar STR Supercharged, = Oil Refinery.... Smile
Post #379606 Thu Apr 04 2013 8:44pm
Agreed, first thing to do is check out the battery. You should see somewhere in the region of 12V when the engine is not running, rising to about 14V when the alternator recharges the battery after starting. The battery might in a poor condition after being imported. It might just need a proper recharge with a battery conditioner or it might even need replacing. 2012 SDV6 - it's missing a couple of cylinders
Post #379609 Thu Apr 04 2013 9:24pm
JPR 1
Hello, I had very similar problems recently, and it was the battery.
Hope you get it sorted and enjoy your new car. Thumbs Up Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #379621 Fri Apr 05 2013 7:30am
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Agreed when the battery gets low all hell breaks loose with warnings. SWMBO owns this car I get to drive occasionally Smile
Post #379785 Sun Apr 07 2013 8:53am
