![]() | Home > Maintenance & Modifications > TPMS Light Help |
Something like the sensor or receiver being faulty and not getting a signal would be the most obvious...if you are sure the pressures are ok. Mike
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
What's really strange is that it won't do it when the temperatures are ~40F of less, but when it gets warmer (50F+), I get the check all tyre pressures message or the blinking light... '12 RRS SC
Turns out it was the TPMS module. Tech said its a known issue w/ the 07 models.
Might not need to synch...
What...you mean my service advisor lied to me?
Nearly 3 years after getting the problem fixed (which included replacing the module), the near same problem is back. The only difference this time is that there's no accompanying message center message to check tyre pressures in all tires. It's also not a consistent issue. For example: the amber light will come on for maybe a second and then go away and do that throughout a short trip. Once I get back in the car and head to another location I may not see the light come on again until the next trip. I can't seem to replicate the conditions that make the light blink, it just does it when it feels like it.
