Home > General > RR sport transmission fault |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
You should have got an inspection sheet on which the mobile should record the actual codes the machine found. The code is far more important than the error so a repairer can diagnose the fault. Hopefully the mobile didn't clear the codes, just simply read them. The error diagnosis by machine is only as good as the software writer and often a fault code can be caused by other issues so the error is not gospel where as the code is. Clear as mud eh 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Mar 18 2013 8:21am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
As above. Just because one fault is stored, does not mean that component is faulty.
Mon Mar 18 2013 8:27am |
steverrsport Member Since: 17 Mar 2013 Location: wolverhampton Posts: 11 |
Ok, But as we have had the car less than 24 hours and has sat out side the house since 4 oclock on saturday afernoon and only getting it 2 hours previous it is going back on a low loader !
Mon Mar 18 2013 8:53am |
Well all sorted, getting my money back tomorrow as over a £1000 + repairs, they wasn't prepared for stratstone to do the work. my prayers answered... |
Mon Mar 18 2013 1:17pm |
That`s what you call a near miss - what's your plans now 16MY Estoril Blue SVR.............
Mon Mar 18 2013 2:32pm |
well i will keep looking and maybe i will find the rite one, as the it was the hse in java black and cream leather thats what combination i want or maybe the stornaway grey and cream leather, but hse will be the minimum spec that i will want. Happy days
Mon Mar 18 2013 2:51pm |
If you find a local one and you want its fault codes read/checked before buying, give me a shout. Bodsys Brake Bible
Mon Mar 18 2013 5:22pm |
Thank you very much, it would be appreciated. |
Mon Mar 18 2013 5:25pm |
pjb Member Since: 04 Mar 2008 Location: Sunny Oxon Posts: 213 |
Hi Steve,
Mon Mar 18 2013 5:50pm |
Hi all, just to let you know i received a full refund today from the garage in Willenhall .
Tue Mar 19 2013 8:59pm |
That is an expensive oil change. One wonders if the first long journey might relight the warning icon 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Mar 20 2013 7:22am |
