Home > Maintenance & Modifications > Part number required
taff
Wales 2006 Range Rover Sport 4.4 V8 SE Zermatt Silver
Anyone have the part number for rear propshaft centre mounting rubber? 2006 4.4 v8, many thanks. Taff. Range Rover Vogue Classic 3.9 V8 1992
101 Forward Control GS 1977
Range Rover Sport SE 4.4 V8 2006
Post #374400 Fri Feb 22 2013 8:07pm
Disco_Mikey
It is not available as a seperate part from Land Rover. They will only supply a complete shaft.
The mount is available as an aftermarket part, but people have tried and had no success fitting them. I had 3 old shafts all with worn mounts, and could not split the shaft without damaging the CV joint in the end of the shaft
Post #374435 Sat Feb 23 2013 7:45am
taff
Ok thanks, just had a service and the mount has a split in it, has not been changed yet but will need doing . Range Rover Vogue Classic 3.9 V8 1992
Post #374444 Sat Feb 23 2013 9:31am
