Home > Technical > Arc pump faulty do have to bleed the system after renewal of
Sixpackal
United Kingdom 2005 Range Rover Sport Supercharged Sumatra Black
Hi I have r rrs supercharged and had a problem with the dynamic suspension, one of the front pipes bust and lost all the fluid , I replaced the pipe refilled with fluid and started the car, all the suspension raised and lowered, there was a fault error light on for the suspension ,but after about a miles there was a loud hissing noise and there was fluid dripping from the arc pump, then a rattle came from the pump and now it's knackered I can get a new one for £550 from the dealer but can I fit this and fill it up or do I have to bleed the system has any one done this before thanks any help would be appreciated .?
Post #373900 Mon Feb 18 2013 6:38pm
Disco_Mikey
There is a bleed sequence on the diagnostic machine, which works the ARC rams through its full travel Thumbs Up
Post #373903 Mon Feb 18 2013 7:36pm
Sixpackal
Don't think I've got the software most
likely a dealer job then ?
Post #373908 Mon Feb 18 2013 8:04pm
Disco_Mikey
Or an indi Thumbs Up
Post #373937 Tue Feb 19 2013 6:57am
