Home > General > Quick Towbar question
Kristian_TT
2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi everyone,
Just received my RRS and im very pleased with it so far apart from that I cannot get the towbar off. I have the key but cant get it into the lock. However, i can pull the green handle out, does that mean that its already open?
Thanks in advance
Kristian
Post #371853 Fri Feb 01 2013 11:12am
Kristian_TT
No one?
Post #372103 Sun Feb 03 2013 9:05pm
RRS_PAT
Hi,
On mine I found I needed to twist the green handle to get the tow bar to lock and allow me to remove the key. If you are new to doing the towbar I suggest you try this. It is kind of the opposite to you as I could not remove my key
Have you tried just pulling the green bit out and twisting that as if unlocked that should release. 2011 Autobiography Santorini Black
Post #372106 Sun Feb 03 2013 9:16pm
Endjin
Scotland
Have a look at this instruction video.
Although it's not the LR Branded towbar it's exactly the same.
http://www.youtube.com/watch?v=p2j5zrg1JxE
Hope it helps Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #372183 Mon Feb 04 2013 3:08pm
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
I still find mine a little difficult but you just need to ensure you twist the key correctly and use a little force. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #372184 Mon Feb 04 2013 3:12pm
Kristian_TT
Not really as what I want to know is wheter or not you can pull the green handle out when its locked.
Post #372185 Mon Feb 04 2013 3:13pm
Green handle will pull out about 5mm when it's locked, thats all.
It pulls out further and you can twist it when it unlocked. ON THE WAY: BMW F21 M140i
Post #372187 Mon Feb 04 2013 3:20pm
as Bean has said, it will still pull out, but you will not be able to twist it (anti-clockwise) if it's locked.
it it twists but still does not release, a bit of elbow grease and give it a shake... Thumbs Up RRS gone
Post #372190 Mon Feb 04 2013 3:50pm
It may already be unlocked and stuck slightly out of position so that the mechanism hasn't released the bolt in to the housing as it would be when fully fitted. The problem is that if the hook has been left in place for a while it might be corroded and feel fully fitted even if it's not.
I'd be tempted to try some WD40 style treatment on the hook where it goes in to the receiver. Then, after a suitable soak time, try to move the hook itself.
The hook can be a slightly tempremental little sod at times. 2012 SDV6 - it's missing a couple of cylinders
Post #372202 Mon Feb 04 2013 5:21pm
Kristian_TT
Thanks for the replys. Ok, i guess that its still locked then since ive tried wd40 several times and also a rubber mallet with no luck.
Post #372379 Tue Feb 05 2013 8:16pm
