Home > Maintenance & Modifications > Pic request - Grey 05-09 with black headlight internals |
Mike_S Member Since: 03 Dec 2012 Location: Dunstable Posts: 15 |
I fitted mine in the fog lamps as DRL on with ignition and then used this controller to switch them off when sidelights (auto lights) come on. It also has a dim function which I didn't use. Easy to fit and good service from the seller
Thu Jan 24 2013 5:43pm |
GAZB Member Since: 02 Feb 2013 Location: NORTH WEST Posts: 83 |
Are the headlights east to take apart , are there any guides with photos |
Fri Feb 22 2013 5:00am |
I recently bought a set of headlights that had been modified by Revere , the indicator on the headlight is now the sidelight but it has a nice L.E.D light fitted in it and the indicator is now at the side of the sidelight , the internal bezals have been colour coded silver which is the same has my RRS however ive split them because I wanted to repaint them black and fit a set of Halo rings , the side reflectors too have been painted silver , im unsure whether to leave just the side reflectors silver to break it up a bit or would you paint the lot black , ill upload a photo of my headlight in my gallery for you guys to see |
Mon Mar 18 2013 12:13pm |
