Home > Technical > Instrument Panel Illumination
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Hi, for some time now in the cold weather when I start up and switch lights on, no instrument or centre console lights for a while, then they will just come on when they feel like it, interior temp come up a little.. when I took to dealer they worked fine, they kept car overnight but indoors so not cold enough..
it's not a problem as such, but could get dramatically worse if suddenly all the lights go out
any ideas?
TDV8 HST 2008
Andrew
Post #370258 Sun Jan 20 2013 6:59pm
lee157
Hi Andrew,
I can't take credit for this but found it on the disco3 site, but I have had the same issue in the cold weather, if you have a wiggle with the instrument dimmer by the light switch on the right then they should come on.
Hope this helps, it did for me, I live with this but guess the permanent solution is a new light switch etc.
Lee
Post #370297 Mon Jan 21 2013 12:32am
