Home > Maintenance & Modifications > 2007 2.7td v6 alternator replacement
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Hi guys
Does anyone know how easy it is to replace alternator on 2.7 td v6 is to do
If its straightforward could do with instructions if anyone has a copy of the relevant manual
Thanks
Post #369869 Thu Jan 17 2013 10:14pm
Does this help?
http://www.rrsport.co.uk/gallery/albums/us...emoval.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #369872 Thu Jan 17 2013 10:24pm
DrLex
Iceland
It's not too difficult - guide for D3 here (it's identical under the bonnet).
(edit: Gah! Beaten like a red-headed step-child!)
Post #369874 Thu Jan 17 2013 10:25pm
ronniet101
Thanks
A big thanks to you guys. The info has been absolutely perfect
Post #369896 Fri Jan 18 2013 7:34am
DrLex
Iceland
You're welcome. If you've a warm garage, today's probably a good day to do it.
IIRC, an OEM alternator from LR may be priced on the basis you return the old one. There are non-OEM alternatives which are cheaper, and without the exchange requirement, so if you've electrical skill, you may find that diode pack replacement will restore functionality on your old unit. I'm sure there's a post on such on the D3 site.
Post #369935 Fri Jan 18 2013 10:32am
Bavo
As you said, getting the Fan undone is the hardest bit. BIG hammer needed and the faith that it is Left Hand Thread. Made an adapter to hold pulley (10mm spanners kept disappearing into the undertray). Anyone in Derby/Burton area wants to borrow it you're more than welcome.
Will load an image as soon as I suss out how to do it. Confused
Also ebay LOADS dearer than Hunters main dealer. Got the 500400 for £201+VAT. Cheap as chips.
Post #370134 Sat Jan 19 2013 4:54pm
