Home > Technical > Periodic fault warning being displayed
Woody185
United Kingdom 2008 Range Rover Sport TDV6 S Stornoway Grey
Hi,
I have a 2008 RRS 2.7 TDV6 and recently and it onyl happens periodically I can be driving along and a series of fault warning lights come on and the display is telling me that the hydraulic suspension failure, then Engine fault warning, then electronic handbrake failure and so on. If I pull over and turn the engine off and restart then all the warnings disappear.
has anyone seem this before and knows what it might be? Woody
Post #369038 Fri Jan 11 2013 4:52pm
PEACHY
Is it whilst the cars still cold or after its reached its operating temperature? Question 16MY Estoril Blue SVR.............
Post #369042 Fri Jan 11 2013 5:08pm
Welcome Smile
As a first port of call, check the battery and possibly the alternator.
Also, check you don't have any brake lights out.
Could also be the steering angle sensor, all sound silly things, but have been known to cause intermittent faults. Thumbs Up ON THE WAY: BMW F21 M140i
Post #369044 Fri Jan 11 2013 5:15pm
Woody185
Thank you for your replies.
The first few times this happened was after a cold start and I was only 1/2 from my house. However last weekend I was on the motorway and it happened after I had been driving for an hour. Woody
Post #369050 Fri Jan 11 2013 5:37pm
PEACHY
I had the same kind of problem - I put up with it for a few months thinking it was going to cost big bucks. It turned out to be a temperature sensor in a hose on the coolant system - because it was faulty the car was thinking it was overheating even though there was no warning from the gauge in the car. It's a quick fix & costs about £15 for the part -can't say its definitely the problem but don't rule it out. Thumbs Up 16MY Estoril Blue SVR.............
Post #369051 Fri Jan 11 2013 5:47pm
Further to beany's list, it could be the brake pedal switch. That has been known to throw some odd errors when it's on the blink. 2012 SDV6 - it's missing a couple of cylinders
Post #369054 Fri Jan 11 2013 5:54pm
Woody185
Hi,
I've been thinking the same, that its going to cost me a fortune.
Thank you for that, I'll check it out over the weekend.
Best Regards Woody
Post #369055 Fri Jan 11 2013 5:54pm
domg
England 2005 Range Rover Sport TDV6 SE Siberian Silver
sorry to hijack your thread
mine has started to do a very simaler thing on a cold start when i drive about 300 meters from my house it will ping on the suspension fault light orange if you switch it off and back on again it goes away and if you start it up in the morning and leave it running for a min, 99% of the time it will not come on
what do people think it might be
Post #369468 Tue Jan 15 2013 4:49pm
GAC23
2006 Range Rover Sport TDV6 HSE Zermatt Silver
I had the HDC failure, transmission fault, lowering suspension messages.
Worried me like crazy til I read this forum ...
Was the brake light switch in my case - a whopping £20 fix Smile
Hope yours is the same.
Post #369618 Wed Jan 16 2013 2:59pm
