Home > Maintenance & Modifications > Wing mirrors keep dipping in reverse?
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
Both my wing mirrors keep dipping when in reverse which makes it so difficult to see anything.
My previous rrs never done this and my friends passenger side wing mirror only does this.
Quite random, is there any way to stop this or am I stuck with this?
Thanks
Post #364957 Thu Nov 29 2012 11:43pm
Put in to reverse and set how you want your mirrors to be then it should go to that position each time you select reverse
Post #364958 Thu Nov 29 2012 11:45pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Harry.
As npinks said.
When in reverse, adjust the mirrors as You want them,
then press "M" on Your seat, and after that "1", to save the setting, You will get a confirmation on Your
Instrument cluster.
Hope that this helps You.
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #364960 Fri Nov 30 2012 12:41am
mark hamster
programme them not to do it.!! mine didnt when i first got car,but i have programmed mine to do it,find it better.its in the book on how to do it Rolling Eyes
Post #364961 Fri Nov 30 2012 4:54am
Disco_Mikey
Reverse mirror dip can be disabled through the settings menu in the dash.
As said, it tells you how to do this in the manual Thumbs Up
Post #364964 Fri Nov 30 2012 6:53am
Harry HST
Cheers guys!!
I will sort this shortly Smile
Post #365004 Fri Nov 30 2012 12:36pm
