Home > General > Mozilla "bush failure" thread - ONLY post experien
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
1) Fault (bushes/suspension/anti-roll bar related)
2) Age of Car and approx mileage
3) Type of Warranty you have (Approved/Select/3rd Party)
4) Finally dealership that went ahead and carried work out under warranty OR as the case maybe REFUSED the work !
1) unknown, was just knocking
2) 10 plate, about 22k miles
3) mfr warranty
4) LPR
(as a side note I had a 57 plate for 3 years, miles up to 45k ish, with no knocking) ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #361636 Fri Nov 02 2012 2:50pm
AndyKay
1) front bushes
2) 2005 with 94k
3) Land Rover Extended
4) Got told it was wear and tear and wouldn't replace them. Got it done for £75 at an independant. RRS HSE TDV6 Autobiography
Post #361640 Fri Nov 02 2012 3:48pm
URX
Scotland
front and rear anti roll bar and ball joints
2009 60k miles no warranty
LR dealership wanted £4k (nearly vomitted when I read that)
independant sorted front ARBs for £100
Post #361642 Fri Nov 02 2012 3:52pm
simple1
2007 TDV8
45000 miles
Front anti roll bar bushes, drop links and bottom ball joints
No warrantee but covered by Land Rover as my car has had so many replaced while under manufacturer cover. Sytnar group Guy Salmon in Bfistol. Downside is have been told Land Rover have now run out of goodwill towards my car after full scale battle over third front diff failure and replacement.
I believe LR quote silly amounts to do rear anti roll bar bushes because they "remove" the body. Local independent who worked at old local dealer says they can and are done at dealerships without removing the body or even lifting it. So don't go to a dealer for rear bushes as they rip back end out of doing the job costwise. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #361645 Fri Nov 02 2012 4:01pm
drdelrrs
2009 TDV8
24,000 miles
Rear ARB replaced
Compressor replaced / software upgraded
LR Warranty
Post #361655 Fri Nov 02 2012 5:12pm
fkarim
1) Suspension struggling to rise.
2) Just under 3 years old at the time with 35k miles.
3) Manufacturer warranty.
4) LPR replaced the compressor and relay, upgraded software.
Post #361683 Fri Nov 02 2012 9:49pm
Mozilla
@ RRSboy, thanks for getting this started ! Thumbs Up
I can add my experience here :-
1) Bushes (knocking sound)
2) 2006, 60k miles
3) Hartwell (underwritten by carplan, same as LR mfr)
4) Refused, saying wear and tear.
Post #362136 Tue Nov 06 2012 4:16pm
Bradders
1. Front lower wishbone bushes
2. 2007, 49k miles
3. Warranty Direct
4. Repair approved no problem at all - much to main dealers surprise FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #362153 Tue Nov 06 2012 5:31pm
Mozilla
My Hartwell warranty runs out end of this month (was already on vehicle when purchased) and will be going ahead to purchase WD. Best quote ive had is £575 so far (they started at £877! Shocked )
Post #362155 Tue Nov 06 2012 5:35pm
Bradders
@ Mozilla, my cover is the Extra Care and I got 13 months for £675 with 4 interest fee instalments. It's a pain having to shell out the money for the repair but they do refund it pretty quickly. FF 4.4 V8 Soooo looking forward to this bad boy
Post #362157 Tue Nov 06 2012 5:41pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
1. Front bushes two occasions?
2. 2008 '58' 17000 & 25000 miles approx.
3. Manufacturer 1st occasion, extended 2nd.
4. Ripon landrover supplying dealer.
Now at 29k and touch wood all is good Thumbs Up
Nik 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #362160 Tue Nov 06 2012 6:06pm
1. Front ARB bushes replaced to cure knocking noise
2. 2007 with 55k miles
3. LR Approved
4. Hartwell Oxford
1. Rear dynamic ARB replaced owing to massive leak
2. 2007 with 58k miles
3. LR Approved
4. Hartwell Oxford 2012 SDV6 - it's missing a couple of cylinders
Post #362174 Tue Nov 06 2012 8:46pm
Paddi
1) Knocking sound over any bumps: Front ARB bushes renewed + mass damper kit fitted + ARC bar replaced (owing to alleged fluid leak)
2) Oct 2007 (2008 MY) 33,000 miles
3) No warranty
4) Land Rover Chipperfield 2008 MY Java Black TDV8 HSE
Post #362615 Fri Nov 09 2012 3:39pm
F1_Dragon
1) Knocking over bumps, front ARB bushes replaced
2) 2009 MY10, 42k miles
3) LR Approved (Fault reported within 2 weeks of purchase)
4) Lancaster Welwyn - supplying dealer MY16 SDV6 Autobiography
Post #362628 Fri Nov 09 2012 5:46pm
