Home > Maintenance & Modifications > Hardwiring Blackvue Power Saver |
Hi Muddy, i had a faulty power saver, i'm awaiting delivery of a replacement which should be on tuesday, other than that, yes i'm all sorted thanks. |
Sun Nov 04 2012 12:43pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Just hardwired the Blackvue in the new RRS and had to read my own guide from last time to refresh my memory
Tue Jun 25 2013 8:23pm |
chrisebabes Member Since: 14 Jul 2010 Location: Cornwall Posts: 79 |
Great info thanks guys |
Mon Jul 29 2013 6:26pm |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
Hi Muddy, I am looking at fitting the Blackvue.
Mon Jul 29 2013 7:43pm |
Mon Jul 29 2013 7:59pm |
Tucked up into roof lining and down behind a pillar trim then through hole behind trim for bonnet release
Mon Jul 29 2013 8:59pm |
Thanks Muddy, photos would be great for a simpleton like me. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Mon Jul 29 2013 9:29pm |
Sorry Ravingmad - just realised I never took the photos for you - did you manage or still want me to do it Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Fri Sep 27 2013 2:59pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
I decided not to undo trim and the bonnet release but to extend the earth wire by a few inches, loosen the bolt at the bottom on the RHS of the glove compartment which is attached to the metal frame and push a "U"type connector down onto the bolt between the bracket and the plastic. Even if you don't get it seated right on the bolt it holds in place ok when the bolt is tightened. |
Mon Sep 30 2013 5:43pm |
Strudelbaum Member Since: 07 Aug 2014 Location: Mijas Costa Posts: 38 |
Where did you guys install the camera? I wanted to put mine up on the windshield behind the rearview mirror. I'm just wondering how to run the power cable neatly from the fusebox. I guess I have to rip apart some of the moldings?
Tue Sep 16 2014 10:11am |
There is enough space to tuck the cable away behind the headlining where it meets the screen, then tuck it away behind the pillar trim. |
Tue Sep 16 2014 11:05am |
Cables as Ady said
Tue Sep 16 2014 11:49am |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 |
Good write up, gonna install mine over the weekend Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
Tue Sep 16 2014 12:08pm |
Just being curious - what software are you using for viewing the dashcam footage?
Tue Sep 16 2014 12:14pm |
