Home > In Car Electronics > Sync My Phone Each Time?
Page 2 of 3 <123>
Bodsy
Site Sponsor
Have pm'd you. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #400705 Thu Oct 31 2013 7:02pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I've e mailed you Bodsy
Post #400774 Fri Nov 01 2013 10:38am
GrahamS
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I need a Bluetooth upgrade too to get it to talk to my Android phone.
What's the cost of this please?
Thanks. Thumbs Up
Post #400808 Fri Nov 01 2013 2:56pm
flack
GrahamS
I am passing your way next week if you want it upgrading, have sent you a pm.
Flack Thumbs Up
Post #400814 Fri Nov 01 2013 4:38pm
Rossc77
2006 Range Rover Sport TDV6 HSE Java Black
Hi Bodsy could you also ping me the details of a BT upgrade for my sport please
Regards
Post #400915 Sat Nov 02 2013 7:56pm
Bodsy
Site Sponsor
Will do buddy, three sat here ready to go Thumbs Up Bodsys Brake Bible
See it HERE
Post #400937 Sat Nov 02 2013 10:25pm
Rossc77
Great service matey have mailed you the old will be winging its way back to you shortly
Post #401182 Tue Nov 05 2013 7:32pm
Bodsy
Site Sponsor
Glad to hear it. Thumbs Up Bodsys Brake Bible
See it HERE
Post #401389 Thu Nov 07 2013 9:18pm
dolphin
Hi Bodsy,
Can you add me to your list of people to PM about this phone syncing thing please?
Also want to add speed camera locations to my sat nav...is that possible?
Thanks
RRSport my 2007
(loves to have technical glitches....) Sheep
Post #406255 Sun Dec 15 2013 4:54pm
Bodsy
Site Sponsor
See it HERE
Post #406256 Sun Dec 15 2013 5:09pm
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Hi Bodsy, sorry you seem to be in demand on this one!
Have an 08 plate too, have you seen this issue as a result of a dodgy battery?? Think mine is on the way out and the phone started not auto connecting about a week ago. Would that make sense??
Alex
Post #406257 Sun Dec 15 2013 5:37pm
Bodsy
Site Sponsor
It can do that, make sure battery is fully charged, make sure car has gone to sleep, then disconnect the pos and neg cables from the battery. Short them together (NOT on the battery!) for 10 seconds, then reconnect. That occasionally fixes it. Thumbs Up
But have also seen it stop auto reconnecting for no apparent reason. Confused
Can you select the contacts from the phone on your radio screen when you are connected? If you've never had that feature, then your on the older software anyway.
Check the above, then let me know if it's something you'd like to do. Thumbs Up
Ian Bodsys Brake Bible
See it HERE
Post #406258 Sun Dec 15 2013 5:45pm
Alex C
Thanks Ian, will get a new battery and try the short fix at the same time. Annoyingly it was all working fine until I deleted the phone from the car by mistake and not been right since.
I have contacts coming through on the car so looks like the latest version.
Steve - if you are reading this standby for a call in the morning for that new battery, looks like it was on the way out after all!
Post #406270 Sun Dec 15 2013 6:59pm
Bodsy
Site Sponsor
Thumbs Up if your in spitting distance of Steve, then you should be sorted Thumbs Up Bodsys Brake Bible
See it HERE
Post #406303 Sun Dec 15 2013 10:10pm
Alex C
Just a follow up on this, it was not the car after all it was my phone......
Took battery and SIM card out and let the phone do hard reset, once this had completed I added back into the car and it works perfectly. Phone was a blackberry which often has software problems that are cured by manual reset. Suggest to everyone with this issue they try Bluetooth with a second phone to check the car system and reset the handset before pulling the car apart or buying a new battery!!
Now I have saved some £££ I have to find something else to buy instead! Smile
Post #406639 Wed Dec 18 2013 5:40pm
Page 2 of 3 <123>
