Home > General > BUYING A RRS
whiskey mac
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
DrLex wrote:
shakeapaw wrote:
Confused i didnt think you could replace the accuator rod on a turbo, at best you just give a shed load of freeing and lubrication agents and hope for the best
LR issued a tech. bulletin in 2010 and then made available an actuator kit last year to supersede the need for replacement in some situations(details on D3 post).
LR wrote:
Lack of power, P132B or P132E stored in the PCM (Powertrain Control Module)
Possible Cause:
Clevis bolt seized into the actuator arm.
Action:
If seizure of the clevis bolt is identified as the root cause, the current service repair is to replace the turbocharger assembly.
Turbochargers are now supplied to the latest condition containing a greased actuator pivot arm/bolt.
Cut off vin numbers are as follows –
Range Rover - AA316114 (3.6 TDV8)
Range Rover Sport – AA229558 (3.6 TDV8) and AA232709 (2.7 TDV6)
Discovery – AA526504 (2.7 TDV6)
 paul
Post #364394 Sun Nov 25 2012 4:54pm
whiskey mac
whiskey mac wrote:
Possible Cause:
Action:
Quote:
Quote:
hi thanks for that info
 paul
Post #364395 Sun Nov 25 2012 4:59pm
