Home > Faults & Fixes > Turbo A Performance Control Sensor
CADjockey
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Help...
Had an Engine System Warning for a while, a while back. Had a new Turbo to fix that (ouch!)
but almost immediately had a new Engine System Warning. No great shakes, no red lights on the dash,
just the irritating LCD message.
Anyway, long story short, had it on a diagnostic thing yesterday and it said "Turbo A Performance Control Sensor".
Anyone tell me what the Censored that might mean? Do I just need a new sensor bearing in mind the Turbo is
basically brand new?
Thanks all...
Post #358698 Thu Oct 04 2012 10:09am
jdgeary1
2006 Range Rover Sport TDV6 HSE Sumatra Black
Ive just had a similar fault. Basically mine came up with an engine system fault. It went in and the diagnostic said turbo fault. I had the turbo replaced as the electronic control system thats on the side of it failed. It was all warranty so didnt cost me. From what I can gather or assume, the control system is an integrated part of the turbo so you cannot just replace one without the other. So it looks like the turbo needs to come off again possibly to resolve the issue you have.
I know the garage said to me that its a stupid place to put the control unit, as its on the side of the turbo and obviously is affected by all the heat thats generated. Why they couldnt put a vacumn hose and reposition it somewhere else is beyond them.
Post #367285 Fri Dec 21 2012 9:46am
panpicker
I had the same thing turned out to be a sticking Actuator easy fix mine just been done car never been better. Common fault
can get to it from underneath and lube up.
Post #367413 Sat Dec 22 2012 9:10am
jagspete
2007 Range Rover Sport TDV6 S Buckingham Blue
Re: Turbo A Performance Control Sensor
CADjockey wrote:
Help...
Thanks all...
Just wandering how much was the turbo? tdv6s 2.7 2007
xkr 5 2010
Post #386688 Sat Jun 22 2013 8:41pm
