Home > Faults & Fixes > Roof lining wet |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
I had his problem in my RRS the drain off pipes were blocked. The pipes run down your left and right A pillars and drain out in the wheel arches. If the water can't drain off because the pipes are blocked it will back up in the pipes, overflow in to your roof lining once the tray that collects the water is full! The water will run about on top of the roof lining as you drive under acieration it will run to the back, if you park on a slope it may run to the rear of the roof and settle there? I had it run out of the interior light fitting under breaking!
Mon Sep 24 2012 6:46pm |
Best way to unblock drain tubes is to blow them clear Mike
Mon Sep 24 2012 8:20pm |
Alan82 Member Since: 23 Sep 2012 Location: Essex Posts: 5 |
Thats wot I've heard pipes r more than likely blocked taking it to a mates garage Thursday will get him to blow the pipes through and see wot happens . Thanks for the advice |
Mon Sep 24 2012 8:42pm |
Had the drain tubes blown through and thought it had solved the problem . Now realised the bac passenger side carpet is soaking wet . Any 1 had this problem? |
Mon Oct 08 2012 5:52pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Hi Alan,
Mon Oct 08 2012 9:04pm |
